January 8, 2022 at 12:13 am
benjaminCoelho
SubscriberHello,
I am using a classical system coupling model to couple a steady state thermal analysis with a fluent analysis.
while it was working with simple models since I implemented a more complex geometry, everytime i double click on the configution button of system coupling, my screen freezes and Ansys crashes.
February 21, 2022 at 4:39 pmGary Stofan
Ansys EmployeeHello
Possibly the Ansys local settings became corrupt.
Exit Ansys completely.
In the File Explorer address field
Enter: %APPDATA%
...An Explorer Window will open
Open the Ansys folder...
Rename the vNNN folder to vNNN.old for the appropriate version.
( v221 = 20222R1, v212 = 2021R2, etc)
Try opening WB and Mechanical and see if it runs properly
The reason we say to go to %APPDATA% is that it is a hidden folder, and you would have to show hidden folders to browse to it.
For example:
my %APPDATA% refers to :
C:\Users\{my_user_name}\AppData\Roaming
then
C:\Users\{my_user_name}\AppData\Roaming\Ansys\v221
It will re-build the next time Ansys WB is run.
3930
2649
1865
1272
610
