TAGGED: 2-way-coupled-fsi, 2-way-fsi, fluent, fsi, system-coupling
May 3, 2022 at 8:03 pm
dxc200018
SubscriberMay 4, 2022 at 11:34 amRob
Forum ModeratorI don't think you can transmit forces through an interface, I think you need a conformal mesh and that'll give you a wall between the fluid & solid parts. can confirm, as will the documentation, it's not an application area I have much experience with.
May 6, 2022 at 5:52 pmSteve
Ansys Employeeare Breast-duct-interface, breast-air-interface and air-funnel-interface Interfaces or Walls in Fluent? The Fluent model should only have fluid cell zones, can you confirm that's the case?
It would be best to have three Fluid Solid Interfaces defined in Mechanical, one for each of the faces corresponding to: Breast-duct-interface, breast-air-interface and air-funnel-interface
Have you gone through this tutorial yet? This may help answer some questions. For example, you very likely don't need Layering turned on.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/sysc_tut/sysc_tut_reedvalve_fluent.html
May 10, 2022 at 4:41 amdxc200018
SubscriberI found out my problem. They were defined as interfaces and not walls. Defining them as wells seems to allow me to do the coupling. Thanks!
I have another weird error though. https://forum.ansys.com/discussion/39196/strange-error-in-doing-fsi-problem-in-ansys-workbench/p1?new=1
Viewing 3 reply threads- The topic ‘System coupling won’t allow me to create force output in 2 of my fluid interfaces’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
