March 3, 2022 at 1:21 am
eastwave
SubscriberHi, dear friends.
I have a pipe with three ends. There is a liquid inlet from two ends and a liquid outlet from the one end. if I only change the fluid velocity at one inlet end, does ansys calculate how the fluid velocity at the other inlet will change? How can I make this application in ansys? thank you for your help
March 3, 2022 at 12:54 pm
System
SubscriberThis discussion was created from comments split from: Gas Diffusion using Ansys Fluent. -
March 3, 2022 at 12:55 pm
Ansys EmployeeIt depends if it's the same boundary label. If it is then the solver will update, if not then you need to do it. Have a look at the courses at the top of the page to get an idea on what the CFD solvers do.
Trending discussions
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
