March 26, 2021 at 3:16 pm
goktug.yilmaz
SubscriberHi everyone!
I want to obtain tangent modulus from the results of my uniaxial tensile test. I find the picture below on the internet. However, as you can see, there are infinite number of points where you can calculate the slope. To obtain the tangent modulus of my material, which point's slope is required?
March 27, 2021 at 4:14 amramgopisetti
SubscriberE_tan_Calculated / E ratio may be closer to an Elastic-perfectlynplastic case.nE_tan_Calculated = [(1+%EL/100)*S_ult - S_yield ]/ [(ln(1/(1-%RA/100)))- (S_yield/E)]n%EL= % Elongationn%RA= % Reduction in AreanE = ModulusnThe strengths are self Explanatory.nIf you don't know the %RA you can approximate by n%RA =200*%EL/(100+2*%EL)nCheck your other post for detailed answer.nCheers, RamnApril 5, 2021 at 11:46 amgoktug.yilmaz
SubscriberDear sir,nnThank you very much for your help. I am very grateful to you. nCould you please recommend a source to me where I can also see those formulations? nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2600
2086
1317
1108
459
