August 14, 2019 at 9:23 am
August 14, 2019 at 2:01 pm
Ansys EmployeeYou need to model the effect on the fluid in the tank? Or are you looking at the effect on the concrete bit?
August 14, 2019 at 5:06 pm
asder
Subscriberdear sir,
i modeled the tank and i gain all modes of shape from modal analysis
my problem is time history superposition analysis
i found some codes for an example like
IF,transient,EQ,1,THEN
/SOLU
ANTYPE,TRANS
TRNOPT,MSUP,10,DAMP
TIMINT, ON, STRUCT
*DIM,force,table,5001,1,1,TIME,,
*TREAD,force,input4,txt,,
DELTIM,1E-4,1E-6,1E-4,ON
AUTOTS, OFF
OUTRES,,1
!TM_START=1E-4
TM_START=0.0
TM_END=0.5
TM_INCR=1E-4
i=0
*DO,TM,TM_START,TM_END,TM_INCR
i=i+1
OUTRES,,1
NSUBST,1
TIME,TM
value=force(TM)
*STATUS,VALUE,1,,1,,1,,
F,N_F,FZ,value,,,
SOLVE
*ENDDO
FINISH
does it right ? if i use acel,timehistorytable,0,9.8 does this load function is right ? i use it for superposition but i found the results is modes shapes only and frequency changed to time , this isn't right solution , why i get that solution -
August 19, 2019 at 2:27 pm
asder
SubscriberIF,transient,EQ,1,THEN
/CONFIG,NRES,1000000000
/SOLU
ANTYPE,TRANS
TRNOPT,full
*DIM,ACC,TABLE,12002,1,1,TIME
*TREAD,ACC,seismic-recorded,TXT
OUTRES,ALL,ALL
DMPRAT,0.005
!TM_START=0.005
TM_START=0.005
TM_END=60
TM_INCR=0.005
i=0
TIME,TM
ACEL,%ACC%,0,9.8
SOLVE
*ENDDO
FINISH
or this
August 19, 2019 at 5:59 pm
jj77
SubscriberStop copy pasting code without any explanations first thing.
You said: my problem is time history superposition analysis, try running it with the full method (not mode super position).
If you are still having troubles, explain in detail what the problem is, and attach images to show what you mean in your explanation so we can understand.
August 22, 2019 at 10:12 pm
asder
Subscriberi will next few days, thank you friend , do you work in 3D-BASIS-ME-MB software ?
2078
1291
1106
459
