Target volume/mass flow rate for multiphase
    • BevisPrivett
      Hi all.
      I am aware it is not possible to set a target outlet mass flowrate for the pressure-outlet option for multi-phase. I want to fix the volume (or at least mass) flowrate out of a bottom run off valve, at the moment with mass-outlet specified I have to input the mass flow of both phases, however, this is something I am not sure of. I just know the volume flowrate which the pump is pulling. See picture below.
      Forum Moderator
      Not an easy one at present as the boundary conditions aren't well suited to this. There are a couple of tricks/options with source terms and fix conditions, but the how is unfortunately beyond what I'm permitted to share via the open community.
    • BevisPrivett
      Hi Rob I got help from ANSYS, they recommended changing the outlet to a velocity outlet give a negative velocity, you can then calculate the expected velocity and set that as a negative inlet velocity.
      Thanks Bevis
      Forum Moderator
      Thanks for sharing.
Viewing 3 reply threads
