December 22, 2022 at 5:40 am
iqnlo
SubscriberHi guys
I am following this instruction to analyse the mode in the silicon waveguide.Optimizing waveguide geometry for single-mode – Ansys Optics
However, the four modes in the figure are labelled as TE1, TE2/TM1, TE2/TM1, TM2
May I ask why there are so many TE2/TM1, TE2/TM1 and no TE0, TM0?Thanks a lot!
December 22, 2022 at 3:40 pm
Guilin Sun
Ansys EmployeePlease check the mode profile and compare with the TE0 definition to identify what mode it is.
December 22, 2022 at 3:42 pm
- Error on Lumerical device
2656
2120
1347
1118
461
