temperature dependent coefficient of thermal expansion value
    • Praveen95
      I have the temperature dependent CTE values varying from 22°C to 180°C, now suppose I want to give thermal BC of -40°C, what would  be the value of CTE in this case and how Ansys workbench Considers this.
      Thanks in advance
      Best Regards
      Praveen
    • SaiD
      Hello Praveen,
      Ansys Workbench will use the CTE value that is closest to -14 C (i.e. the CTE for 22 C) in this case. However, be sure to understand the difference between secant CTE and instantaneous CTE while defining the material properties. See Section 2.1.3 in: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_thry/thy_str1.html%23structempdep
    • Praveen95
       Dear Sdeogeka,
      Thank you for your satisfactory reply.
      Best Regards
      Praveen
