Temperature dependent Young’s modulus
    • Samir Kadam
      If my Young's modulus is temperature dependent, Young's modulus at which temperature will be used in fatigue analysis?n
    • Aniket
      If Young's Modulus is temperature dependent, then the fatigue calculations are carried out using the Young's Modulus computed at the reference temperature of the body. Basically, for strain-life, we are not using the temperature-dependent elastic modulus based on the applied temperatures but only using the elastic modulus evaluated at the reference temperature of the body (Details view of the Geometry branch > Body object). nIt is worth noting that, since 19.1, we added temperature-dependent S-N curves (stress-life): https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v191/ai_rn/dsFatigueE.html nI hope that helps!nAniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
