‘Temperature Divergence in AMG Solver’ in Simulation of Heat Exchanger with Thermoelectric generator
    • Waleed Ghayas
      I am simulating a hexagonal heat exchanger with a TEG chip attached to it. To simply the simulation, we only used one-sixth of the heat exchanger for the simulation. However, when the simulation was run, the temperature solution diverged.
      When I replaced the TEG chip with a simple block of ceramic material, keeping all boundary conditions the same, the simulation ran without
      divergence.
    • mli
      Please provide more details on boundary condition settings.
    • Waleed Ghayas
      I am using a Realizable k-epsilon turbulence model with standard wall functions. The boundary conditions are shown below:
      h_ is 60 W/m2K
      h is 600 W/m2K
