February 28, 2022 at 5:46 am
Dilini
SubscriberHello,
I've got a simple UDF that contains the initial temperature values in my domain changing with depth. I have used a scalar and assigned the temperature values in it. Below is a part of my code.
DEFINE_INIT(temp_profile1, domain)
cell_t c;
Thread* t;
cell_t c0;
Thread* t0;
real xc[ND_ND];
real z;
thread_loop_c(t, domain)
begin_c_loop_all(c, t)
C_CENTROID(xc, c, t);
z = xc[2];
if (0 <= z && z <= 7.5)
C_UDSI(c, t, 3) = 295.00;
else if (7.5 < z && z <= 12)
C_UDSI(c, t, 3) = 295.00 - 0.05 * (z - 7.5);
else
C_UDSI(c, t, 3) = 294.775;
end_c_loop_all(c, t)
After I initialize, I expect a temperature value of 295 at top, and a change in the region 7.5-12 m, and a constant 294.775 after that, However, when I view it I get the following.
February 28, 2022 at 4:44 pmRob
Ansys EmployeeWhat size is the model? UDFs use SI so z is in metres.
February 28, 2022 at 5:44 pmDilini
Subscriberz is going from 0 to 55 meters. x is going from 0 to 150,000 m. In the contour plot I have used a scaling factor of 0.001 for x.
March 1, 2022 at 1:15 pmRob
Ansys EmployeeCan you change the scale and plot with node values off? Just realised that 294.775 rounds to 2.95e2 ie the plot is correct but you've not got sufficient digits on the plot to show it.
2666
2120
1349
1132
461
