September 5, 2019 at 10:22 am
astrotoma
SubscriberHello all,
I am running a conjugate heat transfer case of a heated curved closed channel through which coolant flows. Also, I suspect that in this case it is important to mention that the channel wall is rough.
Upon inspection of the converged results, I noticed that there is a temperature jump (discontinuity) across the solid-fluid interface which is relatively large in some parts of the domain. Why is this so?
Thank you.
September 5, 2019 at 10:40 am
DrAmine
Ansys EmployeeCan you please add a contour plot for cross section showing that with mesh lines displayed?
September 16, 2019 at 1:04 pm
2564
2080
1297
1106
459
