September 10, 2019 at 8:06 am
maliuzair
I am simulating reactions using eulerian eulerian multiphase approach, and species transport.
When I turn on the reactions after getting the cold flow stable, I get the problem "temperature limited to 1.000000e+00 in 7 cells on zone 2 in domain 3" (Pic attached). I get this problem with the granular phase which is a mixture, not the other one as described below. I reduced the diameter of mixture granular phase from 2 mm to 0.5 mm, but of no use. rest of the details are as follows
2 granular phases
a) 0.5 mm, mixture
b) 0.5 mm (not mixture)
1 continuous phase (mixture)
Geometry:
cell size: 3mm
bottom: velocity inlet (continuous phase)
side: velocity inlet (granular phase a (mixture))
top: pressure outlet
walls: temperature: 1020 K, no slip for continuous phase, free slip for granular phases
initial conditions:
sand initial volume fraction: 0.6, Temperature: 1020 K
Air: temperature: 673 K
Biomass (introduced later when the cold flow is stabilized): 423 K
Drag: air-solid: Huilin Gidaspow
solid-solid: Syamlal Obrein symmetric
Evaporation-condensation model: Lee
Heterogeneous Reactions: UDF
Homogeneous reactions
September 10, 2019 at 8:13 am
September 10, 2019 at 9:58 am
Ansys EmployeeTurn the reactions off and see how it behaves. If the reaction rate is UDF controlled what stops it pulling heat from a cell if (for example) activation energy is reached?
September 10, 2019 at 2:50 pm
September 10, 2019 at 4:17 pm
Ansys EmployeeSteady or transient? What do the residuals look like?
September 10, 2019 at 4:23 pm
September 11, 2019 at 9:08 am
Ansys EmployeeIt looks like a rogue hot spot, so may be convergence/gradient related. How's the volume fraction of solids looking? You will probably need to turn off one of the granular phases to see how that behaves then gradually make the model more complex: that's our approach when we work through models from commercial clients.
September 11, 2019 at 9:52 am
maliuzair
Subscribersimulations without reactions converge easily.
the pics of volume fractions are attached. one is volume fraction of sand with bubbles. and the other is the species of the phase for which I am having issues.
My approach for simulations was.:
first I patched sand. NO biomass.
solve for flow and volume fraction.
turn on energy and species once flow is stable. and after some time introduce 2nd secondary granular phase.
September 11, 2019 at 12:53 pm
Ansys EmployeeLooks sensible, so we (you) need to focus on the phase change & reaction rate.
October 8, 2019 at 5:27 pm
maliuzair
SubscriberIs the temperature limited problem the analogous to reverse flow?
I am asking because the temperature limited problem emerges in some cells and then vanishes, and then reappears just like reversible flow appears and vanishes in cold flows (and doesn't affect the solution in general)
October 10, 2019 at 11:22 am
Ansys EmployeeYes and no. It's when something causes the solver to increase/decrease the temperature too far. With phase change it's usually that too much material changes phase in one cell and there's not enough energy available to do that. Ideally once the model is running the warnings disappear.
October 15, 2019 at 2:55 pm
maliuzair
SubscriberAnother question related to my problem but not related to the topic.
Can we use velocity inlet and mass flow inlet simultaneously? are they compatible?
October 16, 2019 at 10:59 am
Ansys EmployeeNot on the same boundary, but yes you can in the same model.
October 1, 2020 at 6:56 pm
Hesam062
SubscriberHi Maliuzair,nDid you solve the problem of Temperature limitation?nI've got the same issue during simulation of biomass gasification in fluidized bed
2600
2086
1317
1108
459
