July 24, 2019 at 10:47 am
zakmt293
SubscriberGreetings
Respected Experts I hope you are fine. I want some info regarding the Phase Change model of Lee. I am working on a growth of single bubble in a super heated domain. I am implementing UDF and this UDF loop through the cells and finds the cells containing both the phases. Then I employ the phase change model of Lee in cell containing both phases.
I am increasing the frequency of evaporation to match my experimental condition.
In the same way I extract the latent by multiplying the mass with latent heat.
Some how after some time the temp goes to 1.0 in vapor of my domain. Can the experts give me any suggestions of why this is happening and what could be the remedial solution for it. I would be thankful for you answer. Any suggestions in any form.
Best Regard
Zeeshan
July 24, 2019 at 11:41 am
DrAmine
Ansys EmployeeI recommend using DEFINE_LINEARZIED_MASS_TRANSFER or DEFINE_MASS_TRANSFER to prescribe the mass transfer.
July 24, 2019 at 3:27 pm
zakmt293
Subscriber@ abenhadj
Thank You for your answer.
I am using define adjust macro through which I find the cell containing both liquid and vapor phase. Then source terms through which I add these mass source.
Would these mass transfer macros effect my results and can I used these mass transfer macros with define adjust???
Thank You
July 24, 2019 at 4:15 pm
DrAmine
Ansys EmployeeBetter to use mentioned as all secondary fluxes are taken into account.
2600
2088
1319
1108
459
