July 11, 2023 at 6:19 am
Rahul Kumar Singh
SubscriberHi. I am trying to simulate the temperaure sensor for High temperature ranges with the help of FBG in Lumerical. But i am stuck after the step of finding the reflection parameter. kindly guide me how to simulate the temperature sensor. the steps mentioned in the help are also not clear regarding the steps to be followed.
July 11, 2023 at 7:28 pm
Guilin Sun
Ansys EmployeeYou will either need to use HEAT solver to simulate the temerature, or have refractive index at different temerature if you know the data. You can import the material refractive index at each temperature in a different material name, and sweep the material at different temperature with different material data.
You can refer to this example for FDTD-HEAT simulation: https://optics.ansys.com/hc/en-us/articles/360041686234-Photothermal-heating-in-plasmonic-nanostructures
July 12, 2023 at 7:03 am
Rahul Kumar Singh
SubscriberThe module available in the lumerical for FBG temperature sensor.... speaks about using the MODE and INTERCONNECT softwares .... kindly gude how to use them for temperature sensor simulation.
July 12, 2023 at 2:55 pm
Guilin Sun
Ansys EmployeePlease follow the steps in the example and if you have questions to a specific step please write a new post for each question.
If you read the intruction you will notice that the FDE model has built-in index change with temerature, which is the 2nd method I suggested previously:
You can change this model, or use HEAT simulation.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7584
4434
2951
1422
1322
