August 29, 2022 at 12:39 pm
am21s079
SubscriberTemperature issue in Natural Convection of 2 Cells enclosed by an aluminium box using MSMD Battery Module.
I have taken t-material and e-material per the manual and assigned them accordingly.
Boundary Conditions:
1. Outer box wall: heat transfer coefficient = 5
2. Other walls are coupled
Problem:
After specific iterations, there is a jump in max temperature. And I'm not getting temperature profiles on cells.
I have attached screenshots of the case. If you need more information pls, let me know.
Thanks for reading. I am extremely hoping for the issue to be sorted out.If any other information is required pls, let me know.
This question was also asked here
you look for more screenshots there.
September 15, 2022 at 12:14 pm
Murari Iyengar
Ansys EmployeeAre you using any expressions or UDFs? Kindly check your BCs and setup. If you are not getting a temperature profile, then most likely the BC is incorrect.
2616
2098
1323
1108
461
