July 4, 2023 at 6:59 pm
Aavash Budhathoki
SubscriberHello everyone,
I am trying to simulate the results of a tensile test using Ansys. My research advisor has provided me with the UTS, 0.2% yield strength, elastic modulus, and Poisson's ratio value for four specimens with different build combinations. I entered the values manually and created new materials in the materials library. Then, I proceeded to use Explicit Dynamics with the following parameters:
Mesh size - 0.001m
Fixed boundary condition, displacement - 0.03 m in 0.001 s
Despite having entered 27 MPa as the ultimate tensile strength value, the stress in the model exceeds that value without any signs of failure. I have been trying to replicate the experimental results for two weeks now but to no avail. I would be highly grateful if I could receive some assistance in this matter.
The material under use is ABS.
July 4, 2023 at 8:27 pm
Armin_A
SubscriberHi Avash,
Have you selected any failure criterion for your material under Engineering Data? You can select from the list of available models (see picture below).
Providing only linear elastic data will not result in failure unless a certain strain limit is reached (accessible via Analysis Settings under "Erosion Controls" in the project schematic).
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
7592
4438
2951
1427
1322
