February 11, 2021 at 2:52 pm
pedrocarneiro
SubscriberHi,nnTo simulate a tension shell concept what is the best type of element to use?n n -
February 12, 2021 at 10:45 am
1shan
Ansys EmployeeHello Array nPlease check the element library for different types of 2D elements available https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/ans_elem/Hlp_E_SHELL181.html. Not sure what you mean by a tension shell but if you want a 2D element with no bending stiffness you could use a shell 181 element with KEYOPT(1) = 1 ( type ET,matid,181 KEYOPT,matid,1,1 in the command snippet). You could directly set the analysis type to 2D and use elements with different formulations like plane stress, plane strain and axisymmetric.nRegards,nIshan.nhttps://forum.ansys.com/discussion/3978/how-to-access-the-ansys-online-helpn
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5290
3311
2469
