Text: “An unknown error occurred during solution.
    • Trangpham
      Hello Everyone
      I am a beginner using ANSYS Workbench 19.2. I am doing ANSYS Magnetostatic. I want to simulate the magnetic field and thermal appearing around two copper wires. I tried doing the steps as following video tutorial:
          but, I  get this error "An unknown error occurred during the solution.  Check the Solver Output on the Solution Information object for possible causes."
      I don't know what the problem is.
      Someone help me check it, please!
    • Karthik R
      Administrator
      Can you please post the screenshot using the 'Insert Image' option so it gets embedded into your question?
      Ansys employees cannot download attachments from the community.
      Thanks.
      Karthik
    • HuiLiu
      Hi if you could share the error message shown in the solve.out file would be helpful to diagnose.
    • Trangpham
       Dear Kremella and HuiLiu,
      thank you very much for your responses,
      I will share for you the error message shown in the solve out file. Please help me check it.
      thank you so much.   ***** ROUTINE COMPLETED *****  CP =         0.641    --- Number of total nodes = 31152  --- Number of contact elements = 0  --- Number of spring elements = 0  --- Number of bearing elements = 0  --- Number of solid elements = 6883  --- Number of condensed parts = 0  --- Number of total elements = 6883   *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  10.7102778      ****************************************************************************  *************************    SOLUTION       ********************************  ****************************************************************************   *****  ANSYS SOLUTION ROUTINE  *****   WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL     FOR ALL APPLICABLE ENTITIES  ****************************************************  ******************* SOLVE FOR LS 1 ****************   SPECIFIED BODY FORCE JS   FOR ALL PICKED ELEMENTS AT STARTING LOCATION      2  IS SET ACCORDING TO TABLE PARAMETER = _LOADVARI111                       SPECIFIED BODY FORCE JS   FOR ALL PICKED ELEMENTS AT STARTING LOCATION      2  IS SET ACCORDING TO TABLE PARAMETER = _LOADVARI115                       USE AUTOMATIC TIME STEPPING THIS LOAD STEP   USE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM  FOR AUTOMATIC TIME STEPPING:    USE     10 SUBSTEPS AS A MAXIMUM    USE      1 SUBSTEPS AS A MINIMUM   TIME=  1.0000       ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.    WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE    FOR ALL APPLICABLE ENTITIES   WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL     FOR ALL APPLICABLE ENTITIES   CONVERGENCE ON CSG  BASED ON THE NORM OF THE N-R LOAD    WITH A TOLERANCE OF 0.5000E-02 AND A MINIMUM REFERENCE VALUE OF 0.1000E-05    USING THE L2 NORM (CHECK THE SRSS VALUE)   *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000       *IF  ANSINTER_                         ( =   0.00000     )  NE         0                                 ( =   0.00000     )  THEN       *ENDIF   *** WARNING ***                         CP =       0.641   TIME= 10:42<img src=7 The Distributed ANSYS solution does not support SOLID117 elements. Distributed parallel processing will be deactivated for this solution. *** NOTE *** CP = 0.641 TIME= 10:427 Distributed parallel processing has been temporarily disabled. ***** ANSYS SOLVE COMMAND ***** *** TREE GAUGING FOR EDGE ELEMENTS *** *** ERROR *** CP = 0.703 TIME= 10:427 *** GAUGE command aborted *** NUMBER OF WARNING MESSAGES ENCOUNTERED= 1 NUMBER OF ERROR MESSAGES ENCOUNTERED= 1 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA ***** +
      D I S T R I B U T E D A N S Y S S T A T I S T I C S
      + Release: Release 19.2 Build: 19.2 Update: UP20180808 Platform: WINDOWS x64 Date Run: 07/17/2020 Time: 10:42 Process ID: 2840 Operating System: Windows 8 (Build: 9200) Processor Model: Intel(R) Core(TM) i5-9500 CPU @ 3.00GHz Compiler: Intel(R) FORTRAN Compiler Version 17.0.4 (Build: 20170411) Intel(R) C/C++ Compiler Version 17.0.4 (Build: 20170411) Intel(R) Math Kernel Library Version 2017.0.3 Product Build 20170413 Number of machines requested : 1 Total number of cores available : 6 Number of physical cores available : 6 Number of processes requested : 4 Number of threads per process requested : 1 Total number of cores requested : 4 (Distributed Memory Parallel) MPI Type: INTELMPI MPI Version: Intel(R) MPI Library 2017 Update 3 for Windows* OS GPU Acceleration: Not Requested Job Name: file0 Input File: dummy.dat Core Machine Name Working Directory
      0 DESKTOP-0CRFAPG C:UsersuserAppDataLocalTempWB_DESKTOP-0CRFAPG_user_4392_2_ProjectScratchScrC639 1 DESKTOP-0CRFAPG C:UsersuserAppDataLocalTempWB_DESKTOP-0CRFAPG_user_4392_2_ProjectScratchScrC639 2 DESKTOP-0CRFAPG C:UsersuserAppDataLocalTempWB_DESKTOP-0CRFAPG_user_4392_2_ProjectScratchScrC639 3 DESKTOP-0CRFAPG C:UsersuserAppDataLocalTempWB_DESKTOP-0CRFAPG_user_4392_2_ProjectScratchScrC639 Latency time from master to core 1 = 2.046 microseconds Latency time from master to core 2 = 2.074 microseconds Latency time from master to core 3 = 2.014 microseconds Communication speed from master to core 1 = 8183.07 MB/sec Communication speed from master to core 2 = 8017.35 MB/sec Communication speed from master to core 3 = 8115.30 MB/sec Total CPU time for main thread : 0.5 seconds Total CPU time summed for all threads : 0.8 seconds Elapsed time spent pre-processing model (/PREP7) : 0.1 seconds Elapsed time spent solution - preprocessing : 0.0 seconds Elapsed time spent computing solution : 0.0 seconds Elapsed time spent solution - postprocessing : 0.0 seconds Elapsed time spent post-processing model (/POST1) : 0.0 seconds Maximum total memory used : 42.0 MB Maximum total memory allocated : 5184.0 MB Total physical memory available : 16 GB Total amount of I/O written to disk : 0.0 GB Total amount of I/O read from disk : 0.0 GB +
      E N D D I S T R I B U T E D A N S Y S S T A T I S T I C S
      * | | | DISTRIBUTED ANSYS RUN COMPLETED | | | |
      | | | | Ansys Release 19.2 Build 19.2 UP20180808 WINDOWS x64 | | | |
      | | | | Database Requested(-db) 1024 MB Scratch Memory Requested 1024 MB | | Maximum Database Used 13 MB Maximum Scratch Memory Used 14 MB | | | |
      | | | | CP Time (sec) = 0.750 Time = 10:427 | | Elapsed Time (sec) = 2.000 Date = 07/17/2020 | | ">
Viewing 3 reply threads
