February 13, 2023 at 6:36 am
pavankonchada123
SubscriberDear Ansys Team
(rpgetvar 'dpm/lowest-mass) and (rpsetvar 'dpm/lowest-mass 1e-24) are not working in ansys 2022r2
Error: rp-var-value: undefined variable
Error Object: dpm/lowest-mass
February 14, 2023 at 7:25 am
pavankonchada123
SubscriberThe above commands are working in ansys 19.2 , Can anybody help me out with this
February 14, 2023 at 7:37 am
Prashanth
Ansys EmployeeHi
I checked in 22R2. You can't use it as that RP command is not available. RP commands are mostly used for internal testing purposes and the changes are not documented.
February 14, 2023 at 8:27 am
pavankonchada123
SubscriberHow to change the lowest mass of the dpm particle. Default value is 5*10^-28. But I want it to be 10^-50
February 14, 2023 at 9:47 am
Prashanth
Ansys EmployeeWhy do you want to decrease the min mass to such a lower value? Are you using any breakup models?
February 14, 2023 at 10:22 am
pavankonchada123
SubscriberI am trying to model the nucleation of vapor which has critical radius near to 10^-14
February 14, 2023 at 4:29 pm
Ansys EmployeeIt's changed. You may want to have a look in the TUI
/define/models/dpm/options
February 14, 2023 at 6:47 pm
pavankonchada123
SubscriberI didnot found any setting to change the default value of mass define/models/dpm/options , please can you help me
February 15, 2023 at 8:10 am
DrAmine
Ansys EmployeeFor changing the lowest mass you require hidden flags. TUI alone is not enough.
February 15, 2023 at 10:15 am
Ansys EmployeeAh, you need to update to 2023R1
/define/models/dpm/options set-minimum-particle-diameter
February 15, 2023 at 11:33 am
pavankonchada123
SubscriberHi Amine, Can you help me with hidden flags concept to set the least mass
in 2023r1 I cant find least mass /define/models/dpm/options
February 15, 2023 at 1:14 pm
DrAmine
Ansys EmployeeI cannot help on that: as mentioned at least two times in this thread the flags are not meant to be exposed on this open forum. You can first assess that TUI way to define the minum particle diameter. You probably won't require that hidden flag for the mass in the newst versions. Just check if lowering the minimum diameter will help particle nucleation.
3670
2552
1751
1226
582
