Text User Interface initialization
    • i.tamunodienye2
      I have a geometry with 2 inlets (gas and liquid). I want to initialize flow from the gas-inlet using TUI. The TUI is the best way to initialize in HPC environment. I am conversant with /solve/initialize/hyb-initialization. I have been trying to achieve the one to initialize from gas-inlet but not been working out.
      Please i need some help.
      Thanks
      Have a look in
      /solve/initialize
      and you'll see several options, have a look in those. It's there.
    • i.tamunodienye2
      These are the options coming up
      /display/set//solve/initialize>
      compute-defaults/ reference-frame
      hyb-initialization repair-wall-distance
      init-flow-statistics set-defaults/
      initialize-flow set-hyb-initialization
      list-defaults vof-patch-smooth-options/
      And not able to manipulate this in fluent.
      I want to get in done in fluent before writing same in HPC
    • i.tamunodienye2
      And this as well
      compute-defaults/reference-frame
      hyb-initializationrepair-wall-distance
      init-flow-statisticsset-defaults/
      initialize-flowset-hyb-initialization
      list-defaultsvof-patch-smooth-options/
    • i.tamunodienye2
      Rob I was able to arrive at this
      /display/set//solve/initialize//solve/initialize//solve/initialize//solve/initialize/compute-defaults> mass-flow-inlet/
      (liquid-inlet gas-inlet)
      zone id/name [liquid-inlet] 26/gas-inlet
      Invalid zone.
      I have tried to go from but been unable. What do i do about the zone id/name. I got the id to be 26.
      Please put in the commands carefully - much of the above looks like repeats and it's not clear what you actually typed in. If it's a multiphase problem you may also need to set the phase domain when setting the defaults.
    • i.tamunodienye2
      This is how it finally displayed.
      So you need to set the boundary type, then name and finally phase to get the default boundary. Then you initialise.
    • i.tamunodienye2
      Do you mean /solve/initialize/compute-defaults/mass-flow-inlet/gas-inlet/phase-1-natural-gas ?
      The aim is to apply it in HPC
      /solve/initialize/compute-defaults mass-flow-inlet gas-inlet phase-1-natural-gas
      Nearly, the / are to separate menu levels beyond that you tend to use spaces. Before you use the HPC always test the journal locally on a small model.
Viewing 9 reply threads
