January 18, 2023 at 6:30 pm
Kenneth Zhang
SubscriberHi support technician,
I am currently working on a project that heavily relies on SPEOS simulation for realism output with texture.
We are trying to resemble a few of our cameras' output using SPEOS.
The bottleneck right now is that SPEOS does not support complicated UV Mapping. For simple cube or sphere object, a watermelon or a pepsi can for example, we could somehow map the texture on properly. But for freeform objects, for example a lizard mage I grab on sketchfab
with Texture like these
We have not idea what can we do to map something a bit more complicated.
I would like to use your expertise and please recommend a few walk around.
How you would approach, if you need to map this texture to the model provided?
any suggestion would be appreciated,
thanks,
Ken
January 19, 2023 at 3:48 pm
Guilin Sun
Ansys EmployeeHi Ken, Speos does not provide a means to handle texture Atlas data natively. This is currently not supported
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2656
2120
1347
1118
461
