October 19, 2018 at 2:49 pm
kzqing
SubscriberHello. I am using Fluent to do a six dof (rigid body) simulation. The model is a valve located in a channel flow. It is a 2D model. The rigid body (the valve ) has only one DOF translation (Y direction in this case) with a spring force. I found that when setting the six dof properties in the "the six dof properties dialog box", the results are different from that when I define the six dof properties in the UDF.
In the "the six dof properties dialog box", I checked "One DOF Translation", enter a value for mass (1kg for example), one DOF direction as X=0 and Y=1, Spring preload=0, Spring constant = 100 n/m, no constrained. Then I set the CG location in the dynamic mesh zones,
While when using the UDF, I defined the followings:
prop[SDOF_MASS]= 1,
prop[SDOF_ZERO_TRANS_Y] = FALSE,
valve_movement_y = (DT_CG(dt)[1] - original_valve_cg_y); /* original_valve_cg_y is the original cg y location */
net_force = (-100 * valve_movement_y);
prop[SDOF_LOAD_F_Y] = net_force;
The results from the udf method show the valve can oscillate up and down, but it didn't do so when using the other method. I can't figure out the problem. Please help me here. Thank you.
October 20, 2018 at 2:00 pm
Raef.Kobeissi
SubscriberHi can you please upload your case with the UDF file.
Regards
October 22, 2018 at 2:17 pm
October 23, 2018 at 1:38 am
Karthik R
AdministratorHello,
Are you trying to use the UDF to exactly replicate your original set-up using the 'Six DOF properties' settings? Is that your final goal? I guess I am trying to understand your motivation behind this UDF. Could you please elaborate?
Thank you.
Best Regards,
Karthik
October 23, 2018 at 2:16 am
kzqing
SubscriberYes, I want to figure out why the two methods have different results. It should be the same, as long as my setup and udf are correct, right? Can you give me some hint where I did it wrong. I would appreciate it. The other settings are all the same.
Thanks,
October 23, 2018 at 9:09 pm
kzqing
SubscriberHello. May I ask if there is any ANSYS support engineer who can help me with my question?
Thanks,
October 24, 2018 at 5:21 am
Keyur Kanade
Ansys EmployeeHello,
As ANSYS employee, we can not download the attachments. Raef can download and check it.
Can you please insert udf in the form of an image. Also please insert images of the case/mesh you are using.
Thanks!
Keyur
October 24, 2018 at 6:21 am
DrAmine
Ansys EmployeeHi, Just to check is your first CG position the same as in the UDF?
October 24, 2018 at 2:49 pm
October 25, 2018 at 12:06 am
klu
Ansys EmployeeHi,
Could you please double check if both cases have the inlet velocity profile hooked? I think the UDF and 6DOF panel basically are equivalent. Thus please make sure all the other settings are the same.
October 25, 2018 at 12:36 am
kzqing
SubscriberHi,
I double and triple checked. I am 100% sure the inlet velocity profile is the same, as well as the other settings except for the "six dof udf/properties". That is why I am confused why the results are different. Hope you can help me here.
Thank you.
October 25, 2018 at 12:48 am
kzqing
SubscriberFYI. One thing I noticed during the calculation is that when using the 'Six DOF properties' panel setting, I need to decrease the time step size from 5e-5s (for the udf method) to 3e-6s (for the "six DOF properties" panel setting), only that the residuals of the dynamic mesh can drop the the value (1e-5) I set.
October 25, 2018 at 5:29 am
DrAmine
Ansys EmployeeCan you verify what the reference length is for the simulation? If not 1m, can you try setting it as such as see if there is still an issue?
October 25, 2018 at 6:18 am
Keyur Kanade
Ansys EmployeeHi,
Can you please cross check your overset and dynamic mesh settings. You can have a look at following video.
Can you please please create test case without spring constant and check.
Keyur
October 25, 2018 at 3:23 pm
kzqing
SubscriberHello Keyur,
I monitored the overset mesh verbosity, there is no orphan cell during the calculation, no dead cell to solve cell reported either. And I did try to run the test case without spring constant according to your suggestion, the results between the two methods become the same. But with spring constant, they are different. So the problem is possibly the spring constant. As for the reference length, the "Depth" showing in the reference values panel is "1m"
Thanks,
kzqing
October 29, 2018 at 8:00 pm
kzqing
Do you know what is the problem here? Your help is greatly appreciated.
Thank you,
kzqing
October 29, 2018 at 9:15 pm
DrAmine
Ansys EmployeeCan you please test with the most actual release?
October 29, 2018 at 9:17 pm
Konstantine Kourbatski
Ansys Employeecould it be the sign convention which is different between the UDF and built in method? Do a quick test by setting Y = -1 in the panel.
October 30, 2018 at 1:54 pm
kzqing
SubscriberHello Amine,
I tried Fluent 19.2. It didn't solve the problem. Neither did setting Y=-1 in the panel. I don't know which method is correct now.
kzqing
October 31, 2018 at 3:35 am
Keyur Kanade
Ansys EmployeeHello Kzqing,
Ok. So you tested without spring constant and the results are same.
Now, can you please test it by giving a constant net force in UDF instead of using any formula.
Also request you to test first without overset mesh. Please use a simple test case.
Lets simplify the problem and go step by step to identify reason for difference.
Keyur
Best practices to fully leverage the ANSYS Academic Community:
Be efficient - As our community grows it is becoming more likely that you are not the first to ask this question. Please search before creating a new post.
Be clear - Provide supporting screenshots, error messages, and background information. No simulation files will be opened by ANSYS support engineers.
Be precise - Please use the right tags to help our engineers find your question.
Be patient - Please allow three days for someone to get back to you, if you have an urgent question, please email your ANSYS Account Manager.
Be helpful - Please help our community grow by answering other's questions and telling your academic colleagues about this resource.
October 31, 2018 at 2:52 pm
kzqing
Hello Kzqing,
Keyur
Hello Keyur,
I tried a constant net force in udf and in the panel with the same preload force but with a spring constant of 0. The displacement of the CG between this two methods are still the same.
Thanks,
Zhaoqing
November 2, 2018 at 6:54 am
Keyur Kanade
Ansys EmployeeDid you change any constraints in the panel?
November 4, 2018 at 1:48 am
kzqing
SubscriberNo one knows the answer? Is it a Fluent's bug?
November 5, 2018 at 8:15 am
Keyur Kanade
Ansys EmployeeHi,
Checked with developer. There shouldn't be any difference between the built in method and UDF, providing the initial spring anchor is identical. When the built-in panel is used, the spring anchor is saved when the user clicks Create in Dynamic Mesh Zones. The CG value specified at this point is saved.
So please check your constraints in 6dof panel and CG in dynamic zones. Also I suggest to use simple test case without any overset mesh.
Keyur
November 5, 2018 at 3:05 pm
kzqing
Keyur
Hello Keyur,
I have changed the test case without overset mesh. The two methods still have different results. I don't know what else constraints you would like me to check. I have attached the setting in the figures, please check. Thank you.
November 6, 2018 at 9:03 am
Keyur Kanade
Ansys EmployeeHi,
I will be out till Monday, 12 Nov. After that I will check this with a test case and will let you know.
Till then others can pitch in.
Keyur
November 12, 2018 at 2:12 pm
Keyur Kanade
I tested with simple case without overset. I tested with GUI option as well as with UDF.
I got same results with both.
Keyur
November 12, 2018 at 2:19 pm
November 12, 2018 at 2:20 pm
Keyur Kanade
Ansys EmployeeHi,
As the results are same, request you to check your other settings.
Keyur
November 12, 2018 at 3:05 pm
kzqing
Thank you very much. I think I found the reason. When I tested both cases with steady state solution as initial conditions, they become the same, but when the initial conditons are both 0, their results are different, i.e. the udf method shows the oscillation of the valve while the panel method does not. It is kind of weird.
November 12, 2018 at 7:36 pm
DrAmine
Which initialization method did u use for the case both results were not matching? Standard? Please add a screenshot.
June 11, 2020 at 3:21 am
linus2
SubscriberHi,
I am simulating a damper model. In the 6dof method, I have given mass and gravity as the input for force and have given spring constant. my piston is also moving.
but the problem is it goes down(-3cm in y-direction) and comes back to its initial position (0,0). after, it is not going upwards instead it goes downwards again(in real case, it should go upwards that is +3 cm in y-direction).
how can I solve this
2630
2104
1329
1110
461
