October 14, 2018 at 1:03 pm
Georgiro
SubscriberThe absolutely serious problem is again to skatch a new model, because I change the dimensions, it change it, but it does not change the dimensions on the drawing - it does not change its lengths, etc. So it is not clear to me what to do with the drawing at all! Thanks The version is up to date. i. e. Ansys 19.2. Thanks
October 14, 2018 at 1:05 pm
Georgiro
Subscriberit does not change its lengths, but the value is there, but the length of the line does not change at all.
October 14, 2018 at 3:49 pm
SubscriberPlease post some screen snapshots of the problem.
October 15, 2018 at 4:16 am
Keyur Kanade
Ansys EmployeeWhat tool you are using? Is it Design Modeler or SpaceClaim. Also insert image to explain.
Keyur
Keyur Kanade
Ansys EmployeeMoving to CAD Geometry category to get better response.
Keyur
October 15, 2018 at 8:07 am
Georgiro
SubscriberOf course Desing Modeler
October 15, 2018 at 8:09 am
Georgiro
SubscriberIt seems to me that Microsoft has made an action to repair my Windows 10 and it seems that this can me the problem, however I have to ask Dell to give me a new Windows 10 to reinstall it, because otherwise I will have a huge problems. But I have to save all the data to my external disk...but what you think about this?
October 15, 2018 at 10:53 am
SubscriberWhere are the screen snapshots of your problem?
October 15, 2018 at 11:02 am
Karthik R
AdministratorHello,
What issues are you having with your copy of Windows 10? If you elaborate on these, we might be able to tell you if they are affecting any ANSYS products.
About your earlier question regarding DM, you might have placed some constraints on your geometry which might be preventing you from modifying the dimensions. As suggested by Peter, you might want to share some screenshots of the same for us to provide more specific answer.
Thank you.
Best Regards,
Karthik
October 15, 2018 at 11:27 am
October 15, 2018 at 11:32 am
Georgiro
SubscriberAnd if you need the complrex view of the whole view, I will do it! And of course I had a problem that they wanted to make a problem I had not to safe any file, but they switch off everything even the internet and I was unable to communicate with them, later on it was impossible to reinstall the laptop and later I have done it, but I may say that this might be a problem with Ansys functionability.
Jiri
October 15, 2018 at 2:30 pm
Ansys EmployeeThe grey colouring implies that you've adjusted one (or more) dimensions or constraints to create an impossible design. Work through the model to see which dimensions conflict (angles, radii tend to be the common ones) and delete the offending dimension or constraint.
An example would be a line is set as a tangent to two circles with a length and then you've changed the diameter of one of the circles.
October 15, 2018 at 3:46 pm
Georgiro
SubscriberThe basic problem is that normally it can change the dimension if you change the dimension/the value, but it did not want to do it. So what can you say in this case. I do not think I can start to think in your way of thinking.
Thanks
October 16, 2018 at 5:13 am
Keyur Kanade
Ansys EmployeeHello Georgiro,
The question is still not very clear.The image and description does not explain your problem in detail.
As rwoolhou has already mentioned, you might have added over-constraints. Please go through your sketch and check which dimensions are in conflict. If you find it difficult, please delete all dimensions and try to give it again one by one.
Also while working on ANSYS student community we use following best practices.
Best practices to fully leverage the ANSYS Academic Community:
Be efficient - As our community grows it is becoming more likely that you are not the first to ask this question. Please search before creating a new post.
Be clear - Provide supporting screenshots, error messages, and background information. No simulation files will be opened by ANSYS support engineers.
Be precise - Please use the right tags to help our engineers find your question.
Be patient - Please allow three days for someone to get back to you, if you have an urgent question, please email your ANSYS Account Manager.
Be helpful - Please help our community grow by answering other's questions and telling your academic colleagues about this resource.
Hope this helps.
Keyur
October 21, 2018 at 3:56 pm
Georgiro
SubscriberBecause I did not have any problem even with working with 15.0.7 and there was not any problem, why I should have a problem with the school 2018 year versáíh 19.2, I really cannot understand the problem. But thanks for the details.
October 21, 2018 at 3:59 pm
Georgiro
SubscriberStill trying to read all your details, but it is not clear to me to find out what shall I do? And especially, my Fluent 15.0.7 worked well, but does not work now at all. So what is your suggenstion? Thanks
October 22, 2018 at 6:13 am
Keyur Kanade
Ansys EmployeeHello,
For every release there would be lot of changes in the code and also usability. So you will find lot of changes from R15.0.7 to R19.2.
Also if model is over constrained then it should not work in R15 as well. So as discussed, can you please explain your problem step by step. You can insert image for each step you are doing. It would help us to identify the issue.
Keyur
November 12, 2018 at 11:02 am
Georgiro
SubscriberOK. I will do it. Thanks
June 10, 2019 at 5:58 pm
Georgiro
SubscriberThe only think that should be here mentioned is that I use only SpaceClaim and it is not possible to finish dimensioning!!! Thanks for ideas! I still have these problems.
June 11, 2019 at 8:57 am
Ansys EmployeeWhat problems? The above images are for DesignModeler. I'll lock this topic as you've marked Keyur's post as an answer. Please start a new topic and CLEARLY state the problem along with images/sketches of what you're expecting/wanting to happen.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
