April 18, 2023 at 12:21 am
Noah Borthwick
SubscriberThe full error message is "An error occurred inside the SOLVER module: The allowed maximum number of layers is exceeded." My geometry is a 2d plane with a layered section. its 12 mm by 1 meter long. Initially, i had 1 90 cm section and another 10 cm section together, each having 5 layeres in a layered section. but even when i reduce it to only 2, it still doesn't work. I am on the student lisence. how do i fix this? -
April 21, 2023 at 2:25 pm
John Doyle
Ansys EmployeeI am not understanding your setup. How does 90cm and 10cm sections relate to a geometry that is 12mm x 1meter long?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5452
3391
2473
1310
1022
