The average thickness of a deformed plate in Mechanical
    • azarandi
      Hi Ansys community
      I was wondering if there is a way or a UDF that I can find an average thickness of a deformed plate in Ansys Mechanical since I cannot import my result into CFD Post anymore after the Ansys 2020 R2 version.
    • Ashish Khemka
      You can use the user-defined results and identifiers to calculate the deformed plate thickness:
      Ashish Khemka
    • azarandi
      Hi Ashish,
      Thank you so much for the hint. Actually, I have not worked with UDFs. Could you please help me with that?
      Amin
    • Ashish Khemka
      Please see if the following link helps you:
      Using User Defined Results in ANSYS Mechanical - PADT (padtinc.com)
      Ashish Khemka
    • azarandi
      Hi Shahish,
      Is there a way to do a mathematical calculation on a quantity? For example, taking the average or integral
      Amin
    • Ashish Khemka
      Hi Amin,
      You can export the quantities of interest in excel and then perform the calculations.
      Ashish Khemka
Viewing 5 reply threads
