July 31, 2020 at 2:14 pm
Keyur Kanade
Ansys EmployeeHello, can anyone help me understand the physical process of condensation?
July 31, 2020 at 2:15 pm
Karthik R
AdministratorHello @kkanade
Condensation is the process of a substance in a gaseous state transforming into a liquid state. This change is caused by a change in pressure and temperature of the substance.
July 31, 2020 at 2:16 pm
prajput
Ansys EmployeeVaporization is the process that occurs when a chemical or element is converted from a liquid or a solid to a gas. When a liquid is converted to a gas, the process is called evaporation or boiling; when a solid is converted to a gas, the process is called sublimation.
July 31, 2020 at 2:17 pm
Keyur Kanade
Ansys EmployeeGot it. Thanks a lot!
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- What is the surface tension of a fluid?
- How to gain research experience?
- Whats the difference between sensible heat and latent heat?
- Cell Counting?
- Why does the total sum of forces acting on a system always have to be equal to zero?
- Why ice floats on water
2706
2142
1357
1144
462
