July 11, 2022 at 1:32 am
huangss_s
Subscriberif the user has the permission to modify the constitutive equation of electromagnetic field inside the software? I look forward to your reply, thank you!
July 11, 2022 at 3:05 am
jackzhf
SubscriberMaterial customization (including electrical, optical and thermal material properties) is avaiable for the design suite and hope the following information will help.
https://optics.ansys.com/hc/en-us/articles/360034394734-Advanced-and-custom-optical-material-models-in-FDTD-and-MODE
https://optics.ansys.com/hc/en-us/articles/360034919093-Electrical-Thermal-material-models-in-CHARGE-HEAT-and-MQW
https://optics.ansys.com/hc/en-us/articles/360034915213-Flexible-Material-Plugin-Framework
https://optics.ansys.com/hc/en-us/sections/360005084893-Materials
July 11, 2022 at 7:43 pm
Guilin Sun
Ansys EmployeePlease do not duplicate the same question!
- Error on Lumerical device
3812
2607
1853
1244
600
