February 27, 2022 at 5:55 pm
cpgeagadir
SubscriberDear community,
I wanted to calculate the dispersion curve, but I don't know how to implement the constraint equations with complex numbers in the Apdl command. I found in an article that I have to duplicate manually the unit cell. How can that solve the problem?
Thanks in advance
March 1, 2022 at 9:45 pmChandra Sekaran
Ansys EmployeeFor cyclic symmetry analysis the duplicate method is used. Here the user provides the basic sector. ANSYS creates a duplicate sector of this mesh. The real part is represented by the basic sector and the imaginary part is represented by the duplicate sector. Then constraint equations are written connecting the 'basic' and 'duplicate' sector.
March 6, 2022 at 11:49 amcpgeagadir
SubscriberThanks a lot
March 6, 2022 at 11:54 amcpgeagadir
SubscriberThank you so much
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2614
2088
1321
1108
459
