November 1, 2018 at 3:07 am
ksh8199
SubscriberHello!
I was following the tutorial uploaded in the YouTube.
I downloaded the youtuber's geometry so there will be no problem with the geometry
and i follow up the setting for mesh as he did.
but i faced the warning massage below
"The current Max Size will create too many initial cells in assembly meshing. As a workaround, please increase
the Max Size by a factor of 100 and then scope a soft Size mesh control to all bodies using the current Max Size value."
Is it because of the hardware problem?
Should i run the program in the more powerful computer?
Thanks!
November 1, 2018 at 3:17 am
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2616
2098
1323
1108
461
