March 19, 2021 at 9:03 am
poorlearner
SubscriberI want to know what improvements have been made to LSDYNA in ANSYS12.1 and 16.0 versions. A same k file produces two results, one converges and the other does not converge.n -
March 20, 2021 at 12:14 pm
ramgopisetti
Subscribercan you able to elaborate exactly the issue with your simulation, for further helpncheers,nRamn -
March 23, 2021 at 1:41 am
poorlearner
SubscriberThank you for your reply. What I am doing is moving the wheel on the rail to simulate the actual railway contact problem.After the model is built, the wheel is rotated on the rail to move forward. Such a model is built in such a way that a calculation file - a K file - is a calculation file for the contacts.The results of the same K file solved by the LSDYNA solver of version 16 are different from those of version 12. The results of version 16 do not converge, but the results of version 12 can converge.I guess it is caused by different ways of dealing with damping in different versions of LSDYNA, but I have no scientific basis to support it.So I was wondering if you know why.nThanks again for your help!ncheers,npoorn
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2534
2066
1285
1104
459
Top Rated Tags
