January 29, 2021 at 10:03 am
Yukiko
SubscriberI wonder what is the difference between rectangle and box.nHow HFSS calculate rectangle or box?nHow is the thickness of rectangle?nPlease tell me the difference.n -
January 29, 2021 at 10:18 am
Praneeth
Ansys EmployeeHi Yukiko,nA box is a 3D object while a rectangle is a 2D object. nFor 2D objects the thickness is zero.nThe AEDT tool will do inter conversions between the 3D and 2D object based on the inputs given by the user. For example a box with zero thickness will be categorized as sheet and if you increase the thickness of the sheet then it becomes solid.nAll the best.nBest Regards,nn -
January 29, 2021 at 10:32 am
Yukiko
SubscriberThank you for your quick reply!nn
- Maxwell, HFSS or Q3D?
- Error
5290
3311
2471
