November 12, 2018 at 12:04 pm
November 12, 2018 at 12:42 pm
Keyur Kanade
Ansys EmployeeIf you have geometry in Design Modeler, please create a single part for all bodies. This will give you conformal mesh between bodies.
Please check following video.
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
November 12, 2018 at 6:43 pm
momidor
SubscriberHi,
It's import from .stp file. I can't create single part for these three bodies because they are from three varius type of steel.
Regards
Jurek
November 13, 2018 at 2:56 am
Keyur Kanade
Ansys EmployeeIf you want connected mesh then you will have to create single part.
Do following steps.
Import .stp file
Select bodies in the model tree
Right click and use create new part.
Now a new part will be created. You can still assign different types of steel to each body.
November 13, 2018 at 3:18 am
Aniket
Ansys EmployeeHi momidor,
What kkanade meant by a single part is "Single multibody part with 3 different bodies in DesignModeler" so bodies can be separate, with each having different material, only interfaces will be shared.
Moreover, your problem seems more of mesh sizing related, you can use smaller element size and turn off the mesh based defeaturing and see if that helps.
November 28, 2018 at 6:14 pm
November 29, 2018 at 4:37 am
Keyur Kanade
Ansys EmployeeYou have it as Defeature Size - second last from bottom in you image.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1345
1118
461
