Ansys Free Student Software
The download speed of Ansys Student is very slow
    • 唐靖博
      When I download Ansys Student, the download speed is very slow and lower than 100KB/s. The download speed is very fast at any other time. I have changed the internet connection, but it was useless. What is the cause of this problem?
    • 唐靖博
      My name is Tang Jingbo. I am a graduate student from China.
      I'm not aware of any problems on our end. The main server is in the US, are there any checks courtesy of the Chinese govt web rules? If you try again now is the problem still present?
    • 唐靖博
      It is not clear whether there are any checks courtesy of the Chinese government web rules. The problem remains at present. I have contacted with Ansys China. But they didn't find a solution.
      I've got around 6-7Mb/s on my home connection, so it looks like it's OK on our side. I am double checking.
      It's not us. Can you check you're not on VPN (tends to slow things down) and not watching YouTube or downloading Win10 updates.
    • 唐靖博
      I have tried to download the software once again. And I didn't use VPN, watch viedo and download data. But the situation didn't change. It is possible that the download speed is so slow because the resource that I download is abroad. Are there any other ways to download Ansys Student?
      No, just the official Ansys site. However the files are hosted (HQs internet wouldn't cope with the data traffic) so it must be somewhere in the system towards your end.
    • 唐靖博
      I have changed the internet connection and downloaded Ansys Student successfully. But when the installation of the Ansys Student software was complete, the program reported there were errors/warnings. After I rebooted the machine, I can't find the shrotcut and folder from the Start menu.
      What were the messages?
    • 唐靖博
      The message is that the installation is complete and there is an error/warning. But it didn't give any details about the error or warning.
    • George Karnos
      Under the "C:\Program Files\ANSYS Inc\ANSYS Student" directory, there should exist a file named: install.err
      open this with notepad and paste the contents of it to this thread as we are not permitted to open files.
      Thank You!
    • 唐靖博
    • 唐靖博
      Please can you post the text as staff are not permitted to open/download attachments.
    • 唐靖博
      I have resolved the problem. How can I download and install Ansys local help which is convenient to use?
      If you're using Student you can't. The full version has an extra install bundle for local help, it's mainly used by those who run local networks and staff who travel (when Ansys let's us out again).
    • 唐靖博
      I found this bundle didn't include Ansys Mesh. How can I download and use it?
      It does, it's the standard meshing tool in Workbench. The full list is here https://www.ansys.com/academic/students/ansys-student
    • Blair
      Hi how did you solve this problem? I download your .err file and find it almost the same as mine. The following is mine:
      ###### Error #######
      Error executing configuration script 'C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\config\AnsConfigCommon.tcl'
      '"C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\tcl\bin\winx64\tclsh.exe" "C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\config\AnsConfigCommon.tcl"-installdir "C:\Program Files\workbench\ANSYS Inc\ANSYS Student" -rev 211 -dotrev 2021 R1 -scripttosource "C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\config\ConfigCommon.tcl" -sourcedir "C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772" -os_lang zh -install ' terminated after 1 attempts with the following error(s):
      Unknown error
      Exit Code: 1
      couldn't read file "C:\Users\´┐¢´┐¢´┐¢´┐¢´┐¢´┐¢\AppData\Local\Temp\ans_install_tmp5772\config\AnsConfigCommon.tcl": no such file or directory
      Error executing configuration script 'C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\config\AnsConfigTG.tcl'
      '"C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\tcl\bin\winx64\tclsh.exe" "C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\config\AnsConfigTG.tcl"-installdir "C:\Program Files\workbench\ANSYS Inc\ANSYS Student" -rev 211 -dotrev 2021 R1 -scripttosource "C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772\config\ConfigCommon.tcl" -sourcedir "C:\Users\þÄïÞêÂÕ©å\AppData\Local\Temp\ans_install_tmp5772" -os_lang zh -install ' terminated after 1 attempts with the following error(s):
      Unknown error
      Exit Code: 1
      couldn't read file "C:\Users\´┐¢´┐¢´┐¢´┐¢´┐¢´┐¢\AppData\Local\Temp\ans_install_tmp5772\config\AnsConfigTG.tcl": no such file or directory
      and many others having the same form.
    • Blair
      Can you guys help me with this? I tried changing my user name into English, but it did not work.
      Question also asked here, https://forum.ansys.com/discussion/29529/installation-error#latest so I'll lock this thread to avoid confusion and duplication of effort.
      I assume you've restarted the computer since changing the UserID and then reinstalled the software as Admin?
    • 唐靖博
      You need to change your username from Chinese to English.
Viewing 22 reply threads
