Preprocessing
Preprocessing
The enclosure can’t be meshed
    • junu
      I model for natural ventilation flow, I made a rectangular enclosure and a solid part within the enclosure in the Spaceclaim. The solid part can be meshed when I meshed it. But I don't know why the enclosure can't be meshed with any kind of meshing method.
    • Kalyan Goparaju
      Can you please post some images of your geometry? Which software are you using? Is this 2D or 3D?
      Thanks,
      Kalyan
    • Keyur Kanade
      please make sure that you apply correct sizing.
      please see help on sizing.
      also make sure that you do not have any sharp angles or small gaps.
      Keyur
