November 27, 2020 at 2:14 am
MiguelRuiz
SubscriberHello, nI have recently installed the Ansys 2020 R2 and I've come across a problem when opening FLUENT for Setup from Workbench. I was able to get all the way through Geometry and Mesh but somehow, when I try to open Setup, this message is displayed and the application gets stuck:n Opening input/output transcript to file C:\Users\MS\Desktop\Ejercicio\Square Mesh_files\dp0\FFF\MECH\fluent-20201126-200216-20616.trn.nn Welcome to ANSYS Fluent 2020 R2nn Copyright 1987-2020 ANSYS, Inc. All Rights Reserved.n Unauthorized use, distribution or duplication is prohibited.n This product is subject to U.S. laws governing export and re-export.n For full Legal Notice, see documentation.nnBuild Time: May 29 2020 07:26:53 EDT Build Id: 10176 n n2020/11/26 20:02:17 INFO Demo license file \Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic exists.nn --------------------------------------------------------------n This is an academic version of ANSYS FLUENT. Usage of this productn license is limited to the terms and conditions specified in your ANSYSn license form, additional terms section.n --------------------------------------------------------------nHost spawning Node 0 on machine MSI (win64).n[unset]: write_line error; fd=860 buf=:cmd=initack pmiid=0n:nsystem msg for write_line failure : No errorn[unset]: Error in writeline initackn[unset]: write_line error; fd=860 buf=:cmd=init pmi_version=1 pmi_subversion=1n:nsystem msg for write_line failure : No errorn[unset]: Unable to write to PMI_fdn[unset]: write_line error; fd=860 buf=:cmd=barrier_inn:nsystem msg for write_line failure : No errorn[unset]: write_line error; fd=860 buf=:cmd=get_ranks2hostsn:nsystem msg for write_line failure : No errorn[unset]: expecting cmd=put_ranks2hosts, got cmd=nFatal error in MPI_Init: Other MPI error, error stack:nMPIR_Init_thread(805): fail failednMPID_Init(1743)......: channel initialization failednMPID_Init(2144)......: PMI_Init returned -1n[unset]: write_line error; fd=860 buf=:cmd=abort exitcode=68204815n:nsystem msg for write_line failure : No error nnI have already searched within the forums for answers to this problem but I can't seem to find anything related at all. I would really appreciate if someone could enlighten me on this.nThanks in advance.n -
December 1, 2020 at 2:50 pm
dcollier
Ansys EmployeeCould you provide screenshots of the Fluent Launcher settings, all tabs. Sounds like it might be a problem with the MPI you are choosing? Have you chosen Default?n----------------------------nDianann----------------------nDiana L. ColliernLead Systems Support EngineernANSYS, Inc.ndiana.collier@ansys.comn
- The topic ‘The FLUENT application failed to start, Fatal error in MPI Init’ is closed to new replies.
- Crash with Exit code 1073741819
- M1 Mac Issues
- Stair-stepping of all boundary layers occured at 1 locations
- MS ASP.NET Hosting Bundle 6.0.8 error on install
- ANSYS STUDENT 2023 – R2 OPENS INSTEAD OF R1
- GPU License
- “Maximum licensed number of demo users already reached” for Ansys 2023 student
- Terminate the Fluent meshing forcefully.
- Error in Ansys workbench 2023 R2 since installed
- Fluent Meshing Error (Scope To: edges/faces and edges)
8808
4658
3153
1688
1474
