3D Design
3D Design
The geometry is in a format that is not supported or is not configured.
    • omran85
    • Karthik R
      Administrator
      Which tool are you using and what geometry format are you trying to use?
      Thank you.
      Karthik
    • omran85
      thank you for your reply , i try to open  (‎SLDASM. )format but then I try with (STEP.) and it works
    • Karthik R
      Administrator
      Yes, please try and use a neutral CAD model - .STEP or .IGES or .x_t. This should help you overcome the issue.
      Thanks.
      Karthik
Viewing 3 reply threads
