Ansys Free Student Software
The geometry editor was closed abnormally in SpaceClaim
    • TaoZhanping
      Hi, when I open the SpaceClaim from the WorkBench, I click anywhere on the window and it disappear immediately. After a while, it shows the error: The geometry editor was closed abnormally.The interface is shown in the picture and the below part is my desktop.
      When I launch stand-only SpaceClaim, the mouse pointer firstly turns into waiting circular ,but after a while it disappears with nothing happens.
      So what should I do to fix it ? There are many posts in the forum,but I find it useless without the same condition.
      Thank you for your help in advance
    • HuiLiu
      could you try the following steps to clear appdata folder and see if it helps?n1, Exit ANSYSn2, from Start > Runn3, Enter %APPDATA% n4, An folder explorer window will openn5, Open the Ansys folder, rename v192 folder to v192_old (or whatever version you are using) n6, Launch ANSYS again and try refresh the projectn
    • tsiriaks
      @TaoZhanping nIn the future, please do not create a duplicate post. n
