Materials
Materials
Topics relate to Granta Design and more
The hardest plastic
    • javat33489
      Hi all. Guys, please tell me, what is the hardest plastic you know? I want to replace some steel parts with plastic ones. Steel has a yield strength of 500.
    • Onkar P.
      Hi Javat,
      When replacing steel components with plastic several factors need to be taken into account, including the specific requirements of the application. Here are a few plastic materials commonly used as alternatives to steel:
      1. Polycarbonate (PC):
        • Yield Strength: 55 MPa to 75 MPa
      2. Acrylonitrile Butadiene Styrene (ABS):
        • Yield Strength: 35 MPa to 60 MPa
      3. Polyamide (Nylon):
        • Yield Strength: 50 MPa to 90 MPa
      4. Polyethylene (PE):
        • Yield Strength (HDPE): 15 MPa to 25 MPa (2,200 psi to 3,600 psi)
      5. Polypropylene (PP):
        • Yield Strength: 25 MPa to 50 MPa
      Please consult the material data sheets for more accurate material property.
      Regards
      Onkar
      Guidelines for posting on Ansys Learning Forum
      • javat33489
        I have seen such. Need stronger :( Thank you.
    • David Mercier
      Hi, why not looking into the family of reinforced polymer composite? If you use Granta selector, you can easily compare hardness of different polymers in an Ashby Chart. And you can even design you own composite using the Synthesier in Selector or Material Designer.
      • javat33489
        I need material that can be turned
