August 25, 2022 at 2:35 am
ahmed.us.ms
SubscriberAfter uploading the hppc txt file I received this error message " found 1 HPPC data file that in old fluent format, this fitting tool only uses HPPC data in new format that includes the temperature as a variable "
https://drive.google.com/file/d/1qm2aA_xCHnl4baWnCbaZLHRiGcnayfNi/view?usp=drivesdk
So what is the new HPPC new format ?
September 6, 2022 at 1:30 pm
Jose Luis Gonzalez Hernandez
Ansys EmployeeHello,
The format for HPPC data should be :
One file for each combination of SOC and Temperature
If HPPC data depends on temperature,
first line must be: "TEMPERATURE" followed by its numeric value,
second line: "SOC" followed by numeric value,
Third line: "I" and numerica value
The rest of the file is organized in two columns, first is time and second is voltage.
If HPPC data does not depend on temperature, start with second line described above.
Best,
Jose Luis
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
