July 18, 2019 at 9:41 am
llldal001
SubscriberGood day fellow Scientists, Technologists, Engineers and Mathematicians!
I have a question that's been bothering me. I have analytically designed a PMSG and once an RMxprt design was created, the designs matched up closely. The masses, performance etc. no problem at all. Once a 2D Maxwell design was created however, the output power that was produced was roughly 11% lower than expected, i.e. 9.6 MW instead of 10.8 MW. I went through the 2D model and and noticed an option in the Model > MotionSetup option of a starting angle. I changed the starting angle from what was the recommended value, changing nothing else at all and the output of the PMSG sat at exactly 10.807 MW.
I would like to know what the implications are with regards to changing the starting angle, i.e does it change the model etc. Furthermore, are there best practices with regards to selecting the ideal starting angle?
Kindest regards!
- Maxwell, HFSS or Q3D?
- Error
3812
2607
1853
1244
600
