November 3, 2022 at 10:13 pm
h.senyue
SubscriberI use a taper structure to simulate a mode convertion from mode6 in port1 to mode6 in port2, it is the TE2 mode converting to TM3 mode. However, when I sweep the length of the taper in EME. I found the S parameters have a vertical decrease. And the optical field seems like the light stop propagating. It is weird. I can see the mode conversion is there, but I am confused about the results. I have changed the Cell number but it made no sense.
November 4, 2022 at 2:26 pm
Guilin Sun
Ansys EmployeePlease make sure you plot abs(S) or abs(S)^2.
From the profile monitor, it seems the fields are strongly discontinuous. Please check the overlap and power quantities in the later part, and check if the desired modes exist. You may need to modify the number of modes or groups or number of cells. make sure the port size is proper to capture the modes without truncation.
More convergence testing techniques can be found here:
Convergence Testing - Introduction
Convergence testing process for EME simulations
EME Convergence Testing - An Intuitive Approach
November 5, 2022 at 3:00 am
h.senyue
SubscriberIt comes to the right result after I increase the mode number in each cell. Really appreciate for your help!
November 4, 2022 at 6:32 pm
Guilin Sun
Ansys EmployeeLater please post any questions related to Lumerical products in the Photonics forum:/forum/forums/forum/discuss-simulation/photonics/
- The topic ‘The light wave stops propagating in EME.’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Import material .txt file with script
- Absorption cross-section of AuNR excited by prism-based TIR
- How to measure transmission coefficients on a given plane .
- TE Polarization Fraction + Waveguide TE/TM Fraction
- Edge Coupler EME Example Issue
- 2D inverse design grating coupler
- Lumerical Python API Topology Optimization Error 2025 R1
- FDE : Simulation waveguides with electrodes
- Loss of lithium niobate phase modulator
2577
933
792
599
591
© 2025 Copyright ANSYS, Inc. All rights reserved.
