March 19, 2021 at 3:33 pm
uwindsorspz
SubscriberHello everyone,nnI am doing the modal analysis of the structure. Is there any way to summarised the max. deformation under all frequencies at the same time? For now, I need note the max. deformation manually, which is a little time-consuming. Thanks for your answer in advance.n -
March 19, 2021 at 11:51 pm
SubscribernThe deformation of modal analysis is arbitrary. You can request that the max. deformation of every mode be exactly 1.0. Use that and it will take you no time at all to note the max. deformation.nhttps://forum.ansys.com/discussion/2569/comparing-stresses-from-modal-analysis-and-static-analysisn
Trending discussions
Top Contributors
2616
2098
1323
1108
461
Top Rated Tags
