July 7, 2022 at 7:59 am
1996lhl
SubscriberDear sir or madam;
I have a question regarding the memory requirement of FDTD simulation.
As show in figure, for a complete same simulation file, the memory requirement of initialization and mesh are different. In 2015 Linux version, required memory is 385.19 GB; in 2020 Windows version, required memory is only 164 MB. I would like to ask if this is just because of version differences.
For the simulation files, I copied directly and ran in different computers, so the files are totally same.
Source type: mode source; single wavelength: 1550 nm.
Looking forward to your reply. Thank you.
July 7, 2022 at 9:26 pm
Guilin Sun
Ansys EmployeeThe memory estimation is rough, and may not be accurate, and in particular for linux system, in addition to the version difference. I would suggest that you use the newest version and check if they are close.
July 8, 2022 at 2:12 am
1996lhl
SubscriberThanks for reply
~Could you please tell us how much is the latest Linux version? We would like to purchase it.
July 11, 2022 at 7:28 pm
Guilin Sun
Ansys EmployeeThe newest release is on Jul 6, 2022R2 https://www.lumerical.com/downloads/customer/
if you have a license you do not need to purchase again, as you can download and install the newest version. If necessary you can purchase additional licenses. Please contact your account manager for more information. -
July 12, 2022 at 12:28 pm
1996lhl
SubscriberCould you please provide me with the 2020 R2.1 Linux version installation package?
We could not find it on FDTD website because maybe it is too old.
Thanks
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5424
3391
2471
1310
1022
