January 16, 2019 at 11:03 pm
etrl
SubscriberAny ideas on how to fix this error "The mesh file exporter could not resolve cyclic dependencies in overlapping contact regions. Please try to Repair Overlapping Contact Regions."
January 17, 2019 at 10:59 am
January 17, 2019 at 5:21 pm
etrl
SubscriberYes I have, but is suppressing these regions a good idea?
January 22, 2019 at 5:06 pm
Aniket
Ansys EmployeeNo, suppressing all together is not a good idea. They just give you an idea where you have overlapping contacts. You should fix them before proceeding.
February 3, 2019 at 4:47 pm
etrl
SubscriberHow can I fix these overlapping contact regions?
February 4, 2019 at 5:42 am
seeta gunti
Ansys EmployeeYou can create multi body geometry so that contacts are not created at all.
Seeta
February 6, 2019 at 11:07 pm
etrl
SubscriberI do have a multi-body geometry. They are essentially PCBs stacked on top of one another. But how can I avoid this error ?
February 8, 2019 at 10:50 am
seeta gunti
Ansys EmployeeHello etrl,
I hope the following youtubes will help you.
Seeta
February 8, 2019 at 10:53 am
seeta gunti
Seeta
February 8, 2019 at 10:55 am
seeta gunti
Ansys EmployeeContact regions are said to be "overlapping" when the same entity is a member of more than one contact region or when multiple contact regions share the same geometry. Ansys fluent does not support overlapping contact regions. You need find the cyclic contact region and then suppress it.
the following links explains how to repair mesh overlapping
https://www.sharcnet.ca/Software/Ansys/16.2.3/en-us/help/wb_msh/msh_overlapping_contacts.html
Seeta
February 12, 2020 at 3:48 pm
MrRed33
SubscriberIf you reached to this page, as I did before...
Contact regions are said to be "overlapping" when the same entity is a member of more than one contact region or when multiple contact regions share the same geometry...
The other way is to to segment contact faces (because every contact is between two face). you can do that by Boolean operations (imprint faces) in design modeler
May 26, 2020 at 2:08 am
BillPeng
SubscriberClick on each connection and you will see the incorrect ones which need suppressing.
February 1, 2021 at 9:56 am
SKB40
SubscriberI tried doing the boolean face imprint. Still it didn't work. Can you please help.n
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
