December 20, 2019 at 3:33 am
Hinano1206
SubscriberHi.
If you cut the mesh and try to send it to Fluent, you will get this error.
Does anyone know why?
December 20, 2019 at 9:27 am
Ansys EmployeeAre there any better messages in Meshing, as opposed to the "messages" in Workbench?
December 24, 2019 at 8:05 am
Hinano1206
SubscriberWorkbench gives the message "Failed to update fluid mesh component: Error updating cell mesh in system fluid".Meshing gives the message "The mesh file exporter failed during conversion. Please send the data to a support provider."Thank you for your reply.
December 24, 2019 at 9:45 am
Ansys EmployeeOpen Meshing and see if there's a more useful message. The common problems are missing volume mesh (and/or missing volumes!) and overlapping Named Selections.
December 25, 2019 at 3:29 am
Hinano1206
SubscriberI understand the cause. It is because of the name given to the file.I was able to move to Fluent. Thank you for your reply.
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5454
3419
2473
1310
1022
