Preprocessing
Preprocessing
the mesh generation was not successful.
    • Jordan
      currently I am doing a simulation regarding to fuel cell (PEMFC) with 9 different parts combined together. I have successfully created my geometry in Design Modeler. However, I can't seem to mesh my design as it stated there 'the mesh generation was not successful'. I am currently using student edition ANSYS version 18.0. I don't came across with this problem when I am using version 18.1. Just I am curious what are the problems that I am facing now.
      Details of my meshing:
      Assembly meshing - Method : Cutcell
      Relevance : 100
      Sizing min : 0.1mm , max : 0.2mm
      relevance center : Fine
      Thank you.
    • Jordan
      9 parts: 7 solids two fluids
    • Keyur Kanade
      Please use latest version 202R1 and check meshing.
      For cutcell, suggest you to go through documentation.
      Keyur
