Ansys Products
Ansys Products
The Meshing editor does not have a valid license.
    • Alexey1998
      Hi. I use Ansys from universuty licenses. When i use "Mesh" I take title" The Meshing editor does not have a valid license. Please refer the following directory for more information: C:Users???????AppDataLocalTemp.ansys." What can I do here?
    • tsiriaks
      Can you try logging in to the computer with an English username or just create one test (Windows) user account, you can name it something like abc, a123 ?
    • Alexey1998
       Yes. I have username "Alexey"
    • tsiriaks
      When you are logging in as Alexey , open CMD Prompt, then type
      set
      and post the screenshot of the output here
    • Alexey1998
      set
       I undestand you mean. But what should i do? This is screenshot: https://ibb.co/x743FNT
    • Alexey1998
    • tsiriaks
      I meant for you to type 'set' (without quote ' ' ) in the CMD Prompt , then press 'Enter' . This would print out certain info I wanted to see.
      But I think I got the info I needed just by this screenshot that you post.
      Your username is not showing in English. You can see in the CMD Prompt that it's showing
      C:UsersA#####
      So, you will have to create a pure English username Windows account , login as that user, then try the mesh again.
    • Alexey1998
      I make. But I can't change username. Now I try the mesh, but the problem is again. Should I change username? or C:UsersAlexey is correct?
    • Alexey1998
    • Alexey1998
      Thanks. I'm very grateful to you
    • tsiriaks
      That's great ! I'm glad that it's working for you now.
    • Havrilov
      Hi! I have the same problem as Alexey1998 had. But changing language or user`s name hasn`t solved the problem.
      So, this is the CMD prompt:
      tsiriaks, Do you have any suggestions?
    • tsiriaks
      Hi Havrilov,
      Thanks for the info.
      Could you provide screenshot of the issue you see ?
      Thanks,
      Win
    • Havrilov
      I`ve tried to open “Mesh” several times, but hopeless.
    • tsiriaks
      Can you open up that directory that the error is stating (the .ansys folder) , then look for the file with latest modified date, open it up and see the logs at the bottom, does it show any error or denied ?
      Also, can you try temporarily turning off Firewall and Anti-virus on the machine ?
    • Havrilov
      Switching off an anti-virus and firewall didn`t help.
      This is what I have in the latest log after the error occured:
      No active FLEXlm options.
      No active ANSYS Licensing Interconnect options.
    • tsiriaks
      Open CMD Prompt, then type
      move "%appdata%ansys" "%appdata%ansys.old"
      do you still encounter the issue ? If so, mark the timestamp when error occurs in Workbench (column D in the Workbench Messages window) , then go to .ansys folder and check all the files that have timestamp around this time and post screenshots of them all (please also provide the exact date/time, or screenshot of Workbench GUI)
      Thanks,
      Win
    • Havrilov
      I still have the issue.
      I did what you had told me to do, so this is what I've got:
    • tsiriaks
      Open all of those files and post the screenshots or the entries that are around 16/10/2019 16:40:41
    • Havrilov
      This is what I have in these files after problem has occurred (but I wasn’t able to open “.ansys.rnd” file):
    • tsiriaks
      Hmm, I don't see any licensing denial or issue.
      Can you try creating a dummy username like abc , and see if you have issue ?
    • Paul1234
      I try to open ANSYS 2019 R3,but it shows Mechanical failed to open the database: The Mechanical editor does not have a valid license. Please refer the following directory for more information: C:UsersuserAppDataLocalTemp.ansys.I have changed my window account name to Paul ald,but it still shows
    • tsiriaks
      What is the name of the installation package that you used ?
    • Vinwang
      Hi, I'm experiencing the same problem. I have no problem opening the workbench and the designer molder, but have license problems loading the mesh and Fluent from the workbench. Besides, it sounds strange but I can run a blank Fluent window seperately without any problem and run simulations.nnVinn
Viewing 23 reply threads
