March 18, 2021 at 3:47 pm
FERO86
SubscriberRecently i carried out the simulation of Rayleigh-Benard convection inside a Rectangle (Aspect ratio 2:1). For comparing the results with one of the paper. The simulated results plot of Nusselt number vs X (distance) for Ra (rayleigh number 10^4) with boundary conditions: top plate = 325 k, Bottom plate= 295 k, Side walls= adiabatic, fluid: water, Pr= 6.57. are as follow
March 18, 2021 at 3:51 pmRob
Ansys EmployeeRead the Nusselt Number definition in the User's Guide, then look at the values it's using. nMarch 18, 2021 at 4:14 pmYasserSelima
SubscriberWhat is the reference length you are using? Compare it to the characteristic length used in the papernMarch 18, 2021 at 4:35 pmFERO86
SubscriberWhat is the reference length you are using? Compare it to the characteristic length used in the paperhttps://forum.ansys.com/discussion/comment/111466#Comment_111466
Characteristic length which i have used is the height (H) of the rectangle same which is used in paper.nMarch 18, 2021 at 7:06 pmDrAmine
Ansys EmployeeAlso check the reference temperature on which the htc is based and compare to the formulation used in the pape.I remember in the past in similar exercise I just exported the heat flux at the wall along the a line or whatever and made post processing to get Nu outside of the code.nMarch 18, 2021 at 7:06 pmDrAmine
Ansys EmployeeGood luck.nMarch 22, 2021 at 6:33 amFERO86
SubscriberGood luck.https://forum.ansys.com/discussion/comment/111505#Comment_111505
thanks a lot, sirnMarch 22, 2021 at 10:28 amDrAmine
Ansys EmployeeWelcome!nViewing 7 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
