3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
The optimization solution run was terminated. Check the Solver Output on the Solution Information
    • mohdizzatz
      Hi, i've been getting this message " The optimization solution run was terminated. Check the Solver Output on the Solution Information object for possible causes " everytime i tried to do topology optimization on my swing arm. I've attached all the values in the engineering data but still error. What should I do to fix this issue?
    • Ashish Khemka
      Forum Moderator
      Hi Array,nnPlease see if the following post helps:nnArraynRegards,nAshish Khemkan
  • The topic ‘The optimization solution run was terminated. Check the Solver Output on the Solution Information’ is closed to new replies.
